When trying to install hotfix 2020.2.6 HF5, I encounter the odd error
"The version you are tying to install 2020.2.6 is not compatible with the version you have installed 2020.2.6. This installer requires a minimum version of 2020.2.6".
I downloaded the hotfix installer directly from our customer portal. Has anyone else encountered this? Is there a workaround?
Thanks! Brent
