Hi all,
i been creating orion maps. and something weird is the is manual connection is already connected. but when i check the port which are connected seem like not correct information. like the port are different from cdp neighour information.
there are no manual connection defined before this. is there is any command which i can use to remove any manual dependency from Database using SQL.
