Dear All,
i have two nodes of same hardware and with same polling methods, but one is showing hardware health sensor in list resources while the other node has no option of Hardware Health sensor to select.
any one can help in this regard please
Hard to tell here without added detail, your best bet may be a support ticket to look into deeper.
Hi @gohar
Do they have the same hardware and software, operating system version, model...?
If not, I would recommend that you run an SNMPWalk on the node with problems and check the Hardware Health OIDs that SNMP uses: support.solarwinds.com/.../Hardware-health-OIDS
If so, does the node where it does not appear have a resource problem?
Check for OIDs on the devices by SNMP walk, else raise a support ticket for solarwinds engineer support
Check if any of the OIDs are present via SNMPwalk.
https://support.solarwinds.com/SuccessCenter/s/article/Hardware-health-OIDS?language=en_USsupport.solarwinds.com/.../Run-SolarWinds-SNMPWALK
