I am allowing the user to input multiple port descriptions separated by commas which i am receiving in an array.
The goal is print them individually for each port.
below is the script.
script ChangeInterfacesBasedOnDescription (
NCM.Nodes @ContextNode,
NCM.Interfaces[] @TargetPorts,
string[] @Itfname )
// Enter configuration mode
CLI
configure terminal
// Loop through selected interfaces
int @Temp = 0
foreach (@portItem in @TargetPorts)
if (@portItem.InterfaceAlias contains 'GNS')
// Do nothing if it's not a physical interface or Uplink Interfaces
else
if (@portItem.InterfaceType != '6')
else
// Set command
CLI
interface @portItem.InterfaceDescription
name @Itfname[]
@Temp = @Temp + 1
CLI
exit
// Exit configuration mode
CLI
exit
When i execute this remplate i get the below error:
Error: Variable @tempitem could not be matched. Possible causes of this are:
Invalid input: Error:
1) It has not been declared.
Invalid input: 1)
2) You are referencing an entity property which does not exist.
Invalid input: 2)
Any ideas or advise ?
Amit
