Is it possible to monitor the accessibility of node/application from external by Orion? Eg from some agent installed on Internet? My node/application stands in DMZ and I would like to monitor its availability on the Internet.
Regards
There are a number of options available here, depending on the application you wish to monitor:
Application monitoring can be accomplished by dedicated tools to monitor apps, or by collecting and analyzing logs using log management tools. With application monitoring, the end goal is to maximize availability and give customers the best experience.
myccpay
Thank for reply. I tried option 3, but it can be installed only on windows machine, my remote host is linux. Regarding to option 1a, how can I use an agent to monitor the external node?
