Hi All,
Using the Solarwinds-SAM-2022.3-OfflineInstaller.ISO file, I am trying to perform the inline upgrade for my Orion Platform.
however, it has been stuck for more than 4 hours in the below status:
Thank you in advance.
Im sure you have got past this but just in case.
Kill the process and try again making sure the installer is run as admin.
Im assuming snapshots/backups have been taken.
Log with SolarWinds Support if stuck as its the latest version and if issues found they can work on it and help others.
@dodo123, which process to kill ?
Any SolarWinds process make sure all SolarWinds services are stopped before upgrade
