Hi, I'm pretty new to Solarwinds here.
Are the thresholds that dictate the type of status on a summary or detail dashboard for a node only available as percentages?
The problem I have, is that I have a lot of machines with wildly varying volume capacities, some are 800gb, others 2tb, which means if I set the threshold to 90% it will still show a node with 200gb free as Critical on the dashboard.
It would be great if instead of a %., I could set the threshold as a capacity value ie, warn @ 50gb free, critical @ 10gb for example.
Is that possible?
Thanks!
