Corelight NTAs - Is anyone monitoring Corelight NTAs on their Solarwinds Servers. They dont support SNMP and require API monitoring.
Products - Appliance Sensors (corelight.com)
Be reviewing the specifications they have:
An iDRAC, that you can set rights to allow SNMP and that you can point to get SNMPs from one of your Orion Polling Engines.
It seems is a flavor for Linux Servers, and it works like an appliance.
I hope this help.
Not used it, but the API monitor in SLW is pretty reasonable, and if that fails a SAM monitor or a scheduled task calling the API can be used to get data in. Doesnt look like there's a public API ref guide, but you'll probably have access via your support account."swagger" and "auth" are my first searches usually.
