I want to ensure all my devices have the same configuration settings for portions of the config and be alerted when it changes. When is it best to use baseline management vs compliance features of NCM for this?
The Compliance is the way to go...its has remediation & support regex...
HP ProCurve Switches Hardening check.xmlGeneral hardening for HP switches
