I am starting down a bit of a rabbit hole here and wanted to get input.
How do you properly monitor a SQL AG? Do we need to add the AG Listener and use that or should we just monitor the nodes separately? If I go into my Orion console I will see SQLNODE1, SQLNODE2, SQLNODE02 but one of the 02 nodes is the AG and one of the 02 nodes is the actual SQL Node.
