I am currently trying to setup a job that will download the running config and compare that config file to the most recently downloaded startup config file. I would also like to have the comparison shown similar to the results in the Real-Time Configuration Change Detection with the highlighted green and red text. Can someone assist with which pre-selected job would be best in this case? This is for the sole purpose of verifying work has been written away to the startup config. We want to avoid running a command line job for saving the running to startup config because we do testing and this would prevent rebooting the switch to reset the config.
Thank you!
Logan Acup
