I am getting an error while connecting with Python:
Query Test:
Traceback (most recent call last):
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
conn.connect()
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/connection.py", line 414, in connect
self.sock = ssl_wrap_socket(
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 453, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls)
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 495, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ssl.py", line 513, in wrap_socket
return self.sslsocket_class._create(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ssl.py", line 1071, in _create
self.do_handshake()
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ssl.py", line 1342, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: EE certificate key too weak (_ssl.c:997)
During handling of the above exception, another exception occurred:
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='solarwinds.internal.com', port=17778): Max retries exceeded with url: /SolarWinds/InformationService/v3/Json/Query (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: EE certificate key too weak (_ssl.c:997)')))
File "/Users/VENV/sdkorion/query_test.py", line 13, in
results = swis.query("SELECT TOP 3 NodeID, DisplayName FROM Orion.Nodes")
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/orionsdk/swisclient.py", line 23, in query
return self._req(
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/orionsdk/swisclient.py", line 52, in _req
resp = self._session.request(method,
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/Users/VENV/sdkorion/lib/python3.10/site-packages/requests/adapters.py", line 563, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='solarwinds.internal.com', port=17778): Max retries exceeded with url: /SolarWinds/InformationService/v3/Json/Query (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: EE certificate key too weak (_ssl.c:997)')))
Please suggest what can be done to overcome this issue
