Hi THWACK community,
Does anyone know the correct values and construction for the Usages argument of the CreateCustomProperty verb? I'm looking to fully understand it so that I can translate the knowledge into any language I have to use in the future.
This is similar to another old post, but I couldn't reply to it: https://thwack.solarwinds.com/product-forums/the-orion-platform/f/orion-sdk/45467/what-is-syntax-for-usages-dictionary
The Schema listed in the OrionSDK github site for this verb is pending completion: http://solarwinds.github.io/OrionSDK/2020.2/schema/Orion.NodesCustomProperties.html
The default value for this field will create a Custom Property with the following:
I've tried combinations of the following (removed the opening less-than signs of the XML so that it would print in the code block)
ArrayOfKeyValueOfstringboolean xmlns:i="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.microsoft.com/2003/10/Serialization/Arrays">
"IsForAlerting": true,
"IsForFiltering": true,
"IsForGrouping": true,
"IsForReporting": true,
"IsForEntityDetail": true,
"IsForAssetInventory": true
/ArrayOfKeyValueOfstringboolean>
{"IsForAlerting": true},
{"IsForFiltering": true},
{"IsForGrouping": true},
{"IsForReporting": true},
{"IsForEntityDetail": true},
{"IsForAssetInventory": true}
Based on the example on the SwaggerUI page: https://solarwinds.github.io/OrionSDK/swagger-ui/#/Verbs/OrionAPMApplicationCustomPropertiesCreateCustomProperty
...I tried:
"Key": "IsForAlerting",
"Value": true
"Key": "IsForFiltering",
"Value": false
"Key": "IsForGrouping",
"Value": false
"Key": "IsForReporting",
"Value": false
"Key": "IsForEntityDetail",
"Value": false
"Key": "IsForAssetInventory",
"Value": true
Haven't had any luck yet.
Also, if someone knows the above, do you also know what the name would be for the "Account Limitations" usage?
