I’m having issues with SolarWinds and AVTECH’s Room Alert 12S Environmental Monitor when using SNMPv3. Firmware on 12S is upgraded allowing SNMPv3 to be utilized. When running SMNPv3, SolarWinds and the temp monitor don’t sync. They will sync with ICMP and lower versions on SNMP. After multiple calls with AVTECH and SolarWinds, it has been determined that the issue is the AES Mode AVTECH uses. AVTECH uses CFB and our SolarWinds representative said our version of SolarWinds will not support CFB for security reasons. Unless AVTECH pushes out new firmware changing the AES Mode to something SolarWinds likes, SNMPv3 with the AVTECH monitors and SolarWinds won't work. As it stand now. I may have to explore using other temperature probes/environmental monitors.
Is anyone else on the forum currently using a different type of temperature/environmental monitor with SolarWinds utilizing SMNPv3? Is so, how well does the probe/system work and would you recommend the product?
