I'd like to setup a NOC view with a map. The map will mostly have groups of nodes. I would like to give the NOC a way to click on a group name from the map, then click on the name of a node that is down and only display a very select amount of information about the node such as the management IP and some notes or customized details. The details would include circuit info and local contact info. I don't want the NOC to see any other details about the node other than that. I also want administrators to be able to see the normal node details view so I don't want to highly customize that view just for the NOC. Any suggestions on how to do this? Thanks.
