Hi all,
We have been active users of Solarwinds SWQL Studio. We normally use the AD accounts to login into it. The AD Auth stopped working recently for all users.
We are able to access Solarwinds GUI using the same AD account and it works fine. The Auth is working for local accounts in SWQL Studio which are created inside SW but not for the AD Accounts.
The authentication is also failing for python/powershell scripts using the OrionSDK with AD accounts (all of them used to work before).
There was no upgrades performed on Solarwinds, the only change I can think of is Windows OS patching.
I have also checked the Orion.Accounts and AccountSID is not NULL.
SW Product Version: 2020.2.6
Is there anything there I can do to troubleshoot the issue?
