We have ACI setup on Solarwinds: 2 APICs, 4 leaf's and 4 spines.
As per the instructions on the 1 APIC node the poll for Cisco ACI is enabled and works fine.
The rest are also nodes on Solarwinds but do not have the Cisco ACI setting enabled.
The issue we have is with discovery, every 30 minutes (when a rediscovery takes place) the interfaces go into warning state which causes many alerts that makes the whole thing a bit pointless.
What seems to happen is that each time it does a discovery it fails to get all the interfaces which explains why the nodes go into warning.
This is also evident when I click on 'List Resources', I get a different amount of resources each time and usually they don't include the physical interfaces (usually just see port-channels or tunnels).
This issue is only on the leaf's and spines.
Is there anyone out there with ACI that doesn't have this issue and if so did you have this issue or have you done something extra that isn't in the instructions?
I'm wondering if it's a case of the wrong OID's being polled? The whole thing does take awhile so it seems like it's timing out.
FYI I have raised a support call but they think the issue is with Cisco, I'm not convinced but in the mean time if anyone has any advice I very much welcome it
