3rd party DB Connectivity Test Utility Attached (Please download the attachment )
If you want to quickly test a database connection this is it.
You can also use this to quickly execute sql command and see the output in a grid.
Provides exception information to help troubleshoot connection issues. for more details please find the link below.
Database Connection String / Command / SQL Tester Utililty Download Link
Database Connection String / Command / Sql Tester - Home
Quick Database Connectivity Testing
http://sqlblog.com/blogs/andy_leonard/archive/2011/08/26/quick-database-connectivity-testing.aspx
********* DOWNLOAD LINKS FOR SQL SERVER EXPRESS EDITION ******
SQL 2005
http://www.microsoft.com/en-us/download/details.aspx?id=21844
SQL 2005 SP 4
Download SQL Server 2005 Express Edition SP4 from Official Microsoft Download Center
SQL 2008 RTM (MGMT TOOLS INCLUDED )
Download details: Microsoft
SQL Server
2008 R2 SP2 - Express Edition - Microsoft Download Center
SQL 2012 SP1 CTP
Download Microsoft
SQL Server
2012 Express from Official Microsoft Download Center
http://www.microsoft.com/en-ie/download/details.aspx?id=34700
Download Microsoft
SQL Server
********** HOW TO INSTALL SQL SERVER STEP BY STEP GUIDE ***********
http://www.sqlserverclub.com/essentialguides/how-to-install-sql-server-2008-step-by-step-guide.aspx
http://blog.sqlauthority.com/2008/06/12/sql-server-2008-step-by-step-installation-guide-with-images/
http://www.sqlcoffee.com/SQLServer2008_0013.htm
********** DATABASE CONNECTION SETTINGS REQUIRED DURING NPM INSTALLATION *********
In order to verify connectivity from Orion NPM server & SQL DB Server .
Please download SQL Studio Management Client and install on Orion Server to verify the connectivity from Orion server to required SQL Server. ( Please chose required Version as matching with your SQL Server installed )
If you have failure with SQL Studio Please consult your Database Manager for further support.
SQL 2008
http://www.microsoft.com/en-ie/download/details.aspx?id=7593
SQL 2005
http://www.microsoft.com/en-ie/download/details.aspx?id=8961
SQL 2012
Download Microsoft
SQL Server
http://freewareupdate.com/developer-tools/4446-2935693919883077577837190221163836935304436249923857738807915379845127
Step-by-Step: Installing SQL Server Management Studio 2008
Download Link Microsoft
SQL Server
2008 Management Studio Express
http://www.microsoft.com/en-us/download/details.aspx?id=7593
http://www.codefrenzy.net/2011/06/03/how-to-install-sql-server-2008-management-studio/
http://blogs.msdn.com/b/bethmassi/archive/2011/02/18/step-by-step-installing-sql-server-management-studio-2008-express-after-visual-studio-2010.aspx
Video Help
How to install SQL Server 2008 Management Studio Express on Windows 7 - YouTube
Please Note . Orion Configuration Wizard shares the same information as above during installation while connecting with SQL Server .
Please use the same connection information with Orion Database Manager as below
