The limit is 1000 EPS and that is for the whole platform. Polling engines do not increase scale for Log Analyzer.
Hi @dhinagar_j
I am assuming you are talking about LA which was LM in the past
https://documentation.solarwinds.com/en/Success_Center/LA/Content/Release_Notes/LA_2020-2-1_release_notes.htm
https://www.solarwinds.com/log-analyzer
1. They state it can take upto 1000 events per second and it can be retained upto an year based on your DB sizing.
** If i am not wrong 1000 events per second capacity is per instance/server (that is for each of your pollers be it primary or additional). Very similar to other Orion modules.
2. They also state the LM not only sits on your Primary Poller but is deployed on your additional pollers
Use an additional polling engine (APE) specifically designed to be used with LA installation without having to purchase a license for an APE.
All details mentioned here is provided in the links pasted, hope it helps.
Thank you @jvb
@dhinagar_j
As mentioned by @jvb its now pretty clear that 1000 events per second for the whole platform and scale does not increase per APE/PPE as mentioned by me.
