I have this awesome SWQL query which shows all Unmanaged and Muted nodes. I got it from Thwack but I can't seem to find the original post to respond to. My SWQL is not the best and this query is pretty complex, I think because of different people contributing.
Could someone please help me add a simple WHERE so I can filter by a Custom Property (Orion.NodesCustomProperties)?
SELECT
'Unmanaged' as [Status]
,n.Caption AS [Node]
,tostring(tolocal(n.UnManageFrom)) AS [From]
,case when n.UnManageUntil is null or n.UnManageUntil = '9999-01-01 00:00:00' then 'Not set'
else tostring(tolocal(n.UnManageUntil)) end AS [Until]
,case when n.UnManageUntil is null or n.UnManageUntil = '9999-01-01 00:00:00' then '-'
else tostring(daydiff(getutcdate(), n.unmanageuntil)) end as [Days Left]
,n.DetailsURL AS [_LinkFor_Node]
,'/Orion/images/StatusIcons/Small-' + n.StatusLED AS [_IconFor_Node]
,CASE
WHEN ae.accountID IS NULL THEN 'Audit Log Not Found'
ELSE ae.AccountID
END AS [Account]
FROM
Orion.Nodes n
JOIN (
SELECT rec.NetObjectID, max(rec.timeloggedutc) as recent
FROM Orion.AuditingEvents rec
WHERE rec.auditingactiontype.actiontype = 'Orion.NodeUnmanaged'
group BY rec.NetObjectID) mostrecent ON mostrecent.NetObjectID = n.NodeID
JOIN (
SELECT ae.NetObjectID, ae.AccountID, ae.timeloggedutc
FROM Orion.AuditingEvents ae
WHERE ae.auditingactiontype.actiontype = 'Orion.NodeUnmanaged') ae ON ae.NetObjectID = n.NodeID and ae.timeloggedutc=mostrecent.recent
WHERE n.Status = 9
union all
(SELECT
'Muted' as [Status]
,n.caption
,tostring(tolocal(SuppressFrom)) as [From]
,case when SuppressUntil is null or SuppressUntil = '9999-01-01 00:00:00' then 'Not set'
else tostring(tolocal(SuppressUntil )) end AS [Until]
,case when SuppressUntil is null or SuppressUntil = '9999-01-01 00:00:00' then '-'
else tostring(daydiff(getutcdate(), asup.SuppressUntil)) end as [Days Left]
, ae.AccountID AS [Account]
FROM Orion.AlertSuppression asup
join orion.nodes n on asup.entityuri=n.uri
join (
SELECT ae.NetObjectID, max(ae.timeloggedutc) as recent
WHERE ae.auditingactiontype.actiontype in ('Orion.AlertSuppressionChanged','Orion.AlertSuppressionAdded')
group BY ae.netobjectid) mostrecent ON mostrecent.NetObjectID = n.NodeID
join (
Order BY ae.TimeLoggedUtc desc) ae ON ae.NetObjectID = n.NodeID and ae.timeloggedutc=mostrecent.recent
--added by WR
where
-- Added to remove outdated period of muting
tolocal(SuppressUntil) > GETDATE()
AND
tolocal(SuppressFrom) < GETDATE()
-- AND (A.DisplayName like '%${SEARCH_STRING}%' or n.caption like '%${SEARCH_STRING}%' or ae.accountid like '%${SEARCH_STRING}%')
OR
--Added to capture those nodes where the suppress until time is not set
SuppressUntil IS NULL OR SuppressUntil = '9999-01-01 00:00:00'
ORDER BY [node] asc, [status] desc
