Hello,I have two DHCP servers that their polling engine ismanaged by DHCP servers. One of those servers no longer exists and when I try to remove it in DHCP & DNS Management >DHCP Servers tab, not all DHCP servers options are available (Add, Edit, Delete, Scan....only Graph View). do you know the reason? and a second question, to remove scopes from the server that is active, can it be done directly or does it have to be done in the database with Orion Datebase Manager?Thanks a lot.
