Currently I have a CPU Alert/Reset enabled that triggers at 70% for all nodes, and in the Email Reset Alert Message the following is provided:
*** From: Node High CPU Utilization - 70% v.X.X - RESET ***
*** High CPU Utilization Duration lasted for 9 minutes. ***
*** RESET CPU Load: 18 % ***
*** Active Alert ID: 6909071 ***
Reset Alert: I would like to include the following into a SWQL query created report - High CPU Utilization Duration lasted for ${N=Alerting;M=Downtime} minutes and RESET CPU Load: ${N=SwisEntity;M=CPULoad}. I'm running NPM 2020.2.6 HF2, but the Web report tool can't resolve these two strings. I'm new to SWQL and am not fluid with SQL either. I would appreciate any help on this...Thanks in Advance. Will
| NetPerfMon Event Log : Node High CPU Utilization - 70% v.1.3 - on ${N=SwisEntity;M=Caption} - RESET *** High CPU Utilization Duration lasted for ${N=Alerting;M=Downtime} minutes. *** *** RESET CPU Load: ${N=SwisEntity;M=CPULoad} *** *** Active Alert ID: ${N=Alerting;M=AlertActiveID} *** |
