Hi All,
Is anyone here monitoring an ACI network using Orion ?
We integrated it by adding one APIC as mentioned in SolarWinds guide, but the leaf switches were not added automatically, we added them one by one.
Now, they are being monitored as normal switches, no details related to ACI appeared, like EPGs, Vlans, routing details, multicast groups, also UDT is not detecting the connected endpoints ...
Is there anything specific that we need to configure to get those details on Orion ?
It would be great if you can share the way you are monitoring ACI on your side.
Thanks in advance.
