Hi all,
I've been rolling my face on my keyboard over this, and I've done some googling, however I'm having trouble using NCM Compliance to pull the existing aaa and tacacs configs from a variety of Cisco devices.
What I have currently (which does not work - it results in duplicate lines or additional config):
Block Start: ^(aaa|(ip)?tacacs)
Block End: ^(aaa|(ip)?tacacs| \S)+.*(?!\n\s) - The purpose is to end if the next line is not an indent (i.e, no subconfig) but also only if the global config involves aaa/tacacs.
String Match: This has been everything from .* to ^(aaa|(ip)?tacacs| \S)+.+(?=\n\s)?
I'm preeeeetttty new to regex in general, so I really feel out of my depth. Yet I feel like matching blocks that don't end on a ! should be a pretty common problem. Unless I'm just going about this the wrong way.
Thanks all!
Example config - should match everything related to aaa/tacacs.
aaa new-model
aaa authentication login CONSOLE local
aaa authentication login VTY group tacacs+ local
aaa authentication enable default group tacacs+ enable
ip tacacs source-interface Vlan1
aaa session-id common
clock timezone PST -8 0
tacacs-server host 1.1.1.1
tacacs-server directed-request
tacacs-server key CISCO
--- OR - should also match the indented lines.
tacacs server SERVER
address ipv4 1.1.1.1
key 7 randomhashgibberish
any other possible subconfig value
