Apologies, another topic here for custom XML/device templates for backing up configs from an ASA running in multi-context mode.
I have no issue finding posts detailing the commands and values for entering into a custom XML script, but what isn't documented anywhere it seems, is how the device processes the XML? There is a similar post below asking the same question:
ttps://thwack.solarwinds.com/product-forums/network-configuration-manager-ncm/f/forum/42298/cisco-asa-multiple-context-backup-with-ncm-7-2-2-what-has-changed
I have assigned a similar XML against a context firewall, and all that was retrieved was the config of the admin context. And yes, my context names and commands were correct.
Surely the commands need to run in order, such as:
Change to <NAME>
Save config
Change to <NAME>
Save config
Please could anyone shed any light? This seemingly easy request is turning out to be more difficult than expected.
Many thanks.
