Hello everyone,
atm I try to deploy MRC 12.1.2.584 via Microsoft Endpoint Manager (Intune) and i'm using Powershell App Deployment Toolkit for scripting.
I have managed it, to install MRC and to put in the license information automatically during the installation.
Also the uninstallation works without problems.
But if I try to install MRC again on this client, I get an error during installation:
Error in PSADT:
[01-04-2022 13:48:56.613] [Installation] [Execute-Process] :: Executing [C:\Windows\System32\msiexec.exe /i "C:\UnBackedUp_Data\02\Paketierung\Files\DWMRC_St_64.msi" ARPCOMMENTS=LA00078 ARPNO
MODIFY=1 ARPNOREMOVE=1 ARPNOREPAIR=1 LIMITUI=1 COMPANYNAME=XXX USERNAME="User" REBOOT=ReallySuppress ALLUSERS=1 ROOTDRIVE=C:\ MSIFASTINSTALL=7 MSIRMSHUTDOWN=1 MSIDISABLERMRESTART=1 MSIR
ESTARTMANAGERCONTROL=Disable /QN /L*v "C:\LELogs\SWB\LA00078_SolarWinds_DameWareMiniRC_1212584_x64_EN_02_DWMRC_St_64_Install.log"]...
[01-04-2022 13:49:06.420] [Installation] [Get-MsiExitCodeMessage] :: Get message for exit code [1603].
[01-04-2022 13:49:06.420] [Installation] [Execute-Process] :: Execution failed with exit code [1603].
[01-04-2022 13:49:06.436] [Installation] [Close-InstallationProgress] :: The installation progress dialog does not exist. Waiting up to 5 seconds...
[01-04-2022 13:49:11.498] [Installation] [Close-InstallationProgress] :: The installation progress dialog was not created within 5 seconds.
[01-04-2022 13:49:11.498] [Installation] [Exit-Script] :: Installation completed with exit code [1603].
Error in MSI logfile:
MSI (s) (74:F0) [13:49:05:826]: Note: 1: 1722 2: APPDIR 3: C:\Program Files\SolarWinds\Dameware Mini Remote Control x64\ 4: "C:\Program Files\SolarWinds\Dameware Mini Remote Control x64\SolarWinds.MRC.Licensor.exe"
CustomAction APPDIR returned actual error code -532462766 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (74:F0) [13:49:05:826]: Product: Dameware Mini Remote Control x64 -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action APPDIR, location: C:\Program Files\SolarWinds\Dameware Mini Remote Control x64\, command: "C:\Program Files\SolarWinds\Dameware Mini Remote Control x64\SolarWinds.MRC.Licensor.exe"
MSI (s) (74:F0) [13:49:05:826]: Note: 1: 2318 2:
It seems to be aproblem with SolarWinds.MRC.Licensor.exe.
Could somebody give me an advice to fix this.
Thanks in advance.
BR
