Is there any possibility that we can capture which process is running on higher side while we received CPU and RAM utilization alerts
Yes, try using copying and using the "High CPU Utilization with Top 10 Processes" / "High Physical Memory Utilization with Top 10 Processes" / "High Virtual Memory Utilization with Top 10 Processes". Copy those out-of-the-box Alerts and tweak them for your environment.
thanks will try
