Is it also possible to take a backup through SNMP only.
I'm not sure I understand your question. Are you asking if it is possible to back up an F5 load balancer using SNMP?
In general, you can trigger a config backup through SNMP, but the actual tranfer will require TFTP. I don't know if F5 devices support this option.
Regards,
Jiri
Thanks for the information JIRI, also I need your help to backup my f5 device as I am not understanding the correct way and steps to do it.
My device s:- F5 bigip v version 10.2
Help will be really appreciated !
Thanks in advance
