I am starting to monitor my server hardware with SNMP. However while its creating alerts when hardware fails, its not changing the node status when the hardware goes into an error state. So my HUD appears that the server is hunky dory when its really having hardware issues. I saw the feature request was implemented here, but I dont see details. Wouldnt "implemented" indicate that it now should change the node status icon to indicate a hardware problem? https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/i/feature-requests/change-node-status-with-alertsWhat am I missing? How do I get my node chicklets to reflect the hardware status as well as the network status? Note the node status is still green even though there are problems.
@cameramonkey take a look at this article for Enhanced node status. that's what you're looking to do
That helps. I don't see an immediate change on the one problem node, but I suspect that will take a bit to show up. Thanks!
