In an existing environment, is it possible (simple) to remove interfaces (mass remove from nodes)?
In SQL there are possibilities but this access is not always possible.
In a rediscovery it is easy to add new interfaces.
I'm looking for a rediscovery where the import template uses less interfaces.
Now this is not possible (at least I have not found the solution yet)
Yes, I know (its all about licensing)
RJJ-FeatureRequest-002
