This is all good, but what conditions do you set?
I currently have: AppInsight for SQL: Job Info --> Job Status (SQL Job Info Alerting Properties), but I do not know what to set the constraint to ?
Please help...
Note: I found the solution here: AppInsight for SQL - Create an alert for SQL failed jobs (solarwinds.com)
