Hello,
We are adding ESXi host into SolarWinds for some basic monitoring. We are not currently utilizing VMAN. We have successfully added ESXi hosts running 6.5 and 6.7. However, we are getting an authentication error when adding any of our 7.0.2, 18538813 hosts. We have successfully tested the credentials using putty and logging into the ESXi web interface without any issues using the same creds. Solarwnds support is saying we have to contact VMware because it is now a VMware issue and not a SolarWinds issues.
Looking to the community to see if anyone has had this issue with ESXi 7.0.2, 18538813 before. Polling method is using VMware API and like I said, not issues adding hosts running ESXi 6.5 or 6.7. was learning towards a service or firewall issue on the esxi host but I have a lot of common ones turned on or opened.
Any feedback or ideas is appreciated
Thank You
