I'm not a Linux guy so I'm reaching to you all for some help. I need to create a basic Up\Down Alert that checks SSH on Linux servers. Could someone advise on how I would do this and what the command would be for the script body?
Thank you!
Hello Use the wizard in the Same module for creating a template monitor with a component process monitor.
=> In the console, Settings, All Settings, SAM settings, Component Monitor Wizard, Linux - Unix Systems, Process Monitorbest regards.
Hi!!
Follow what @roadcycling stated in their reply. No script should be necessary to monitor the process. You may need ssh credentials so ensure you have that readily available. Good luck!!
