Considering the following output of a two switch stack:
x#show ver | in Model
Model Revision Number : A0
Model Number : C9300-24T
x#show env power all
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C1-350WAC-P xxxxxxxxxxxx No Input Power Bad Bad 350
1B PWR-C1-350WAC-P xxxxxxxxxxxx OK Good Good 350
2A PWR-C1-350WAC-P xxxxxxxxxxxx OK Good Good 350
2B PWR-C1-350WAC-P xxxxxxxxxxxx OK Good Good 350
...I was surprised to find that Solarwinds did not detect the bad power supply. The solarwinds NPM "node info widget" states (custom information edited out):
NODE STATUS Node status is Up.
Node is Up.
POLLING IP ADDRESS x.x.x.x
DYNAMIC IP No
MACHINE TYPE Cisco Catalyst 9300 Series Switch
NODE CATEGORY Network
DNS
SYSTEM NAME x
DESCRIPTION Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.6, RELEASE SOFTWARE (fc1) Technical Support: www.cisco.com/techsupport Copyright (c) 1986-2019 by Cisco Systems, Inc. Compiled Thu 11-Apr-19 03:51 by mcpre
LOCATION
CONTACT
SYSOBJECTID 1.3.6.1.4.1.9.1.2494
LAST BOOT Wednesday, September 25, 2019 11:53 AM
SOFTWARE VERSION 16.6.6, RELEASE SOFTWARE (fc1)
SOFTWARE IMAGE CAT9K_IOSXE
HARDWARE Physical
NO OF CPUS 2
Normally a failed power supply, even one that is just unplugged, would show up as a failure that Solarwinds would flag. Why is it not in this case?
