I am trying to build an Alert Complex Trigger Condition and just like other times I have tried to do this, I am not having any luck. Hoping someone with experience with these can help.
Basically if any of all of the 4 servers in the first section are Down and a 5th server in the second section is Up, trigger the Alert.
I have simplified this down to having:
- A first section with a scope OR block containing 4 Nodes that are currently down in our environment. The trigger condition in this first section uses an AND block and is Node Status is equal to Down.
- The section divider is AND and the second section scope is a AND block with one Node listed that I know is Up. The trigger condition in this second section is Node Status is equal to Up.
- I don't have "Condition must exist for..." or "Alert can be triggered if..." checked in either section.
- The Reset Condition is simply set to "Reset this alert when trigger condition is no longer true" and
- Time of Day is set to "Alert is always enabled..."
- "Evaluate the trigger condition every" is set to 16 seconds.
- Alert Definition is Enabled.
I would expect, when this is saved to, to see an Alert appear in the Active Alerts list within 16 seconds or so but nothing after 10 minutes even.
I did test just the first section and the Summary page said that the 4 down Nodes would trigger Alerts. I also tested just the second section and the Summary page said that 1 Up Node would trigger an Alert.
Here is the Trigger Conditions page:
So what am I doing wrong?
