Running this either via SWIS call or Database Manager:
SELECT [TimeStamp], [EventTypeWord], [Name], [ObjectType], [Message], [EntityCaption], [Severity]
FROM [dbo].[AlertHistoryView]
WHERE [TimeStamp] >= '01/08/2021' AND [TimeStamp] <= '02/08/2021'
ORDER by [TimeStamp] DESC</pre>returns:04/02/2021 13:16 Acknowledged BCM - CPU Utilisation LA 2 Node ******
04/02/2021 13:05 ActionSucceeded BCM - CPU Utilisation Node Event (File) 2 Node *****
04/02/2021 13:05 ActionSucceeded BCM - CPU Utilisation NetPerfMon Event Log - CPU Utilisation 2 Node ******
04/02/2021 13:05 ActionSucceeded BCM - CPU Utilisation Email - CPU Utilisation 2 Node *****
04/02/2021 13:04 Triggered BCM - CPU Utilisation CPU load is 92 % on node ****** 2 Node *****
however running the same query directly on the sql server in sql studio 104 results a sample of which are below, but none of which are the entries returned above (which incidentally fall out of the date time range specified):
TimeStamp EventTypeWord Name ObjectType Message EntityCaption Severity
2021-08-01 23:02:31.480 ActionSucceeded ***** - CPU Utilisation Node Node Event (File) Cleared ****** 1
2021-08-01 23:02:31.277 ActionSucceeded ***** - CPU Utilisation Node Email - CPU Utilisation - Cleared ****** 1
2021-08-01 23:02:30.840 ActionSucceeded ***** - CPU Utilisation Node NetPerfMon Event Log - CPU Utilisation - Cleared ******* 1
2021-08-01 23:02:30.510 Reset ***** - CPU Utilisation Node NULL ******* 1
I can't for the life of me understand why this is.
context should it be required is that I am attempting to automate daily checks that are performed whereby someone manually eyeballs for critical alerts out of hours to ensure they were all picked up and raised in a ticketing system.
I already have a SWIS call to OrionReporting.ExecuteSQL with a far more complex (for me) SQL statement that works without issue, so this being odd for such a simple request is frustrating to say the least.
any help / guidance would be greatly appreciated.
