Can someone advise how I would create an alert based on the thresholds for CPU that are defined in the node properties? I know how to create an alert by setting my own thresholds for CPU in the alert trigger conditions, but I want to be able to customize what triggers the alert at the node level. For example, a SQL server that we know runs high and spikes on CPU compared to all other servers. I'd like to just adjust that node threshold to a different value to prevent it from being in a near constant critical status and triggering an alert.
