Hi
For the Widget: Top 10 Volumes by Disk Space Used we use the following filter to only show us Windows and Unix Volumes.
Caption Like '*:\*' OR Caption Like '*/*'
What I would also like to do is filter out any Windows & Unix Volume that has not exceeded its threshold or is Unmanaged i.e. we have a bunch of volumes that the data is static so its fine for these to sit at say 98% usage.
The Show List of Volume Properties in the Edit section of the widget has some properties that may help but I've so far been unable to to find a solution, which on the face of it you would think should be baked into the tool.
So I was hoping something like this would work but I cant get the unmanaged filter to to work and i'm not even sure any of the properties are suitable for the exceed threshold
(Caption Like '*:\*' OR Caption Like '*/*') AND (UnManaged=??) AND (?? for threshold exceeded ??')
So the long and the short of it I just want a widget showing me the Top XX number of Windows and Unix system which have exceeded their Volume thresholds. Seem to remember this taking 5 mins in Zabbix to set up....I must be missing something?
Thanks in advance
