1) How to configure SNMP on DHCP servers? these servers are Solaris 9.
2) While adding DNS server into IPAM getting error "Syntax error in Bind configuration" Followed below :-
- BIND DNS error - Syntax Error in BIND Configuration
- IPAM BusinessLayer logs
- Command named-checkconf -z "%{ConfigFilePath}" fails with /etc/named.conf:5: open: /var/named/conf/logging: file not found
- As explained by Gladson, BIND is running in a chroot environment. Hence the file /var/named/conf/logging won’t be directly accessible without being chrooted to “/var/named/chroot” path.
Can someone please help me how to change these path in Solarwinds?
3.How can I discover static IPs in IPAM?
4.How can I utilize discovered IPs for informative IPAM Dashboard?
