Looking to upgrade my Orion 2018.2h6 to the latest 2020 version.
My VM admin said I could do a test run using isolated image if I wanted to.
Can the upgraded from 2018 to 2020 be downloaded for updating in an isolated environment? Or is the recommendation to do it "online" so upgrade can pull everything and possibly more directly from internet?
Then we also have the SQL side to deal with, guessing unless my admin can provide that also, using vm isolation for upgrade will fail due to no SQL, yes?
