How do I change the readings in the Last XX Events section to read in mbps or even gbps. Showing readings in bps is stupid. No one has time to set there and count all of the zeros. This should be standard practice that any reading of more the 1000 bps gets moved to a different reading. Whether that be kbps, mbps or even gbps. With 400/800 gbps and 1.6 tbps ports in the works, no one will be able to count all of the zeros to figure out the speed.
So how do I change the readings to be something I can read at a glance?
