The only example I have seen is a PERL example. Looking for something similar but using PowerShell. I plan on combining that with a few other parts I already created. In the end I plan to create groups with a dynamic query. Then select the InstanceId once the group is created and update the worldmap (lat\lon) so I can autogenerate the world map with our 400-500 locations.
props = {
'Instance': 'Orion.Nodes',
'InstanceId': 343,
'Latitude': 38.889963929167,
'Longitude': -77.027206420898
results = swis.create('Orion.WorldMap.Point', **props)
Thanks in advance if anyone can help out.
