This may be obvious to some but what is the difference between Enabled and Enabled with Live mode turned on? I've not been able to find any documentation on this.
Thanks.
To see details about an issue in the history, find the time of the issue in the Path History (1), and click a problematic time slot. Review the path from the past and locate the issue (2). To return to the current time, click Live Mode (3).
Monitor Exchange network performance with NPM (solarwinds.com)
Live mode will auto-update your NetPath representation with the latest data as it comes in. When turned-off, new data will be stored but you will not automagically see it.
