Hi
Kindly help me to generate report in SQL
Node Custom Property = ATM_Branch
Sample Interval:: Day
Need this average availability report of yesterday.
It looks like you are creating multiple posts on the same topic - placing link to other post: https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/f/forum/90392/need-help-is-swql-query
need this report from sql
What do you need to create this report in SQL for? If you are using a custom table, when selecting your Data Source, use the Dynamic Query selection > then object type of Nodes, and then use the "select field" section to select your Custom Property of ATM Branch.
plzzz help
