Centralized upgrade stuck in starting configuration wizard?? Upon checking the configuration wizard logs database not connecting.
We are using custom sql port.
I would reboot the server and start the wizard manaully from the Start menu, but more important, Open an incident with support for a down system. They will get you moving quickly if you haven't already fixed it. ( I see the post is 8 hours old)
