Hello,
I have tried upgrading from 2020.2.4 to 2020.2.5 with the NPM offline installer, HA setup.
Faced few issues while running installer and configuration wizard.
Error when installer first attempt:
Failed: Access to the path 'C:\ProgramData\SolarWinds\Installers\SolarWinds.Administration.ProductCatalog.Model.ProductCatalogModel_installed.json' is denied. (I am part of Administrator)
Error when configuration wizard:
Verifying that the SWIS container storage is available FAILED
Services configuration failed:
• Connection to SolarWinds® Information Service did not succeed.
Last error: RunQuery failed, check fault information.
EntityTypeResolver is not initialized
But in the second attempt everything went fine.
All the service started, the console came up with no menu bar and 'backend services not started properly'
I have tried restarting services, servers, rebuilding website and running configuration wizard. but no luck
We dialed in tech support and they couldn't fix it. He also tried upgrading the MPE secondary server and try to make it Active, but same console issue was there.
Finally rolled back to previous version.
Any help is appreciated..
Thanks in advance.
