Good day,
With our previous system, I was able to deactivate the updates for a specific product in Patch Management.
In our case, for example, Access 2016, the reason was that we had to reconfigure our ERP system every time.
My question, can I do the same here? Or do I always have to deactivate every single patch that comes in for Access 2016 in the patch management workflow?
This way I would have to set the workflow to manual and would not be able to install critical updates directly because, as I said, I always have to check whether the individual product is included.
Thank you
