Hi Community,
We have several hundred Harris/Stratex Microwave devices most with multiple radio cards we urgently need to monitor. The SNMP setup is very strange and is not really compatible with SolarWinds. They seem to use the community string more like a "context". Let me explain.
The System detail can me accessed using the community string "terminal". Using a set of Universal Pollers I can collect the information about the cards in the device, their asset information and base status. If I need more information like the frequency, modulation method or receiver signal level (RSL - that's the important one) I need to use the community string related to the slot the card is in i.e. if the Radio card is in slot1 of the chassis, the community string would be "slot1", the OIDs related to the Radio card are populated for that card. If there was another card in say slot3, the community string would be "slot3" and the same OIDs would be populated with it's data.
When I raised this problem with SolarWinds Support and their response was "raise a feature request". However, given there seems to be little chance they will ever implement anything that will help us, I'm turning to the Community...
Cheers, Peter
