Hi everyone, can someone please tell me whether or not how I can find out if I had the Orion log viewer installed on my old orion system. I have access to the database but not to the website (we shut the old servers down and will not be bringing them back up). There must be some table somewhere I can check and see. I honestly have no idea if I had it installed or not. We are spinning up new Orion servers to connect to the database and I don't want to mismatch anything.
Also, does anyone else know whether or not it will be feasible to add or remove it once the system is up and running?
Thanks.
