We decided to spin up new servers in response to the security exploit. Would I need to run the 2020.2.1 installer and then the HF2 installer or does the HF2 installer contain the entire package
I actually just tested the hotfix installer and they will install everything for you.
i am going to be in the same boat as my security team refuses to allow the old servers to come back online - are you going to use the same DB or are you starting fresh across the board
If you are going to start fresh I would download the NPM installer (check date stamp) from the customer portal and install any other applications from there as it will have the latest hotfix included in that build.
